Anyone ever have to solve a problem with a sticky ballast pump? Or have an impellor get "spun", in which the pump drive shaft does not stay seated on the impeller, and spins through the center hub?
I haven't taken the cover off of the pump impellor housing yet, but I imagine I will see that the impellor has been "spun", and the pump shaft is jammed and is unable to turn because the plastic has built up after having been torn out of the impellor hub.
Has anyone else encountered this issue, and if so, can you help me understand the causes and ways to prevent it from happening? This is a pump which has been replaced under warranty previously, and which just began acting up on Sunday (had a huge crew Sunday so no need for tankage ballast.
I looked at it yesterday and the pump fill light at the helm lights up but pump remains silent. At least it is the starboard pump, and most of us are port side surfers.
Any thoughts or suggestions? I expect when I open it up and see it today, it will be bound up because it has been spun. . .
TIA.
TIA.
