Jabsco water puppy won't run in reverse
  • jslow68
    • Apr 2006
    • 73
    I had a dealer install a ballast system with Jabsco water puppy's. They worked great last summer. I couldn't get the center ballast pump to work. They had the same color wires for the negative and positive. I realized I hooked it up backwards andI blew the inline fuse. I replaced that. Now It will fill but not reverse to empty. I did see two relays wired to the pump. Could one of those be bad or would it be something else?
  • surroundsound64
    • Jul 2005
    • 2148
    • Longview, TX
    • 2026 S23 1981 Ski Nautique
    I had this happen yesterday. One of the wires on the back of the switch had come off, easy fix. Checking all the connections is about all you can do short of pulling a multi meter out.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • mnwakerider
      • May 2011
      • 271
      • Minneapolis, MN
      Did you change the inline wiring on the pump side or switch side? If you flipped the polarity on the pump, that shouldn't matter, pump would only run opposite to what it was wired, as the pumps are designed the flip polarity to run in forward or reverse.
      Agreed on SurroundSound - it has to be at the switch side, if you are getting power to the pump in one direction, that removes the issue from the pump side. Check your wiring and if there is nothing loose check the power levels at both leads on the pump with a multimeter. Do it in both fill and drain. If you are getting less than 12v check for bad connections. Those ballas puppy's really draw a lot of amps and dont like anything less than 12v.
      • jslow68
        • Apr 2006
        • 73
        That makes sense that it would be at the switch. I'll check that next and let you know what I find out.
        thanks!
        • puhuta
          • Jun 2010
          • 7
          • `06 Air Nautique SV-211
          Having the same problem with my Jabsco "water puppy." jslow68, were you able to locate the problem? Thx.
          • jkallen21
            • Jan 2013
            • 400
            • United States
            • 2006 Super Air 220
            It could simply be the impeller. Open it up and see if it's even trying to go backwards. If it is, buy new impellers. In fact, if you're opening these up, have new impellers on hand. The upside-down angle of the pumps is not fun to do twice.
