Impeller Help
  • usmc23
    • Feb 2005
    • 10
    • Arlington, TX
    Impeller Help
    Where is the impeller located on a 1980 Ski Nautique? How do i remove and repalce?
    • 2909
    • Current 2017 GS22
    RE: Impeller Help
    1. Lift the motor box.
    2. Follow the water pickup hose from the hull, it may have a strainer, it will have a trans cooler, third stop will most likely be the impeller housing.
    2. alternative, one of the fan belts goes out to the alternator the other one goes out the toe raw water pump that houses the impeller, it's the one with hoses not wires.
    Welcome to inboards!
