1995 GT 40 problems
  • polkaking27
    • Jan 2005
    • 104
    1995 GT 40 problems
    I had the engine rebuilt over the winter and got it back on the lake for the first time on Saturday. Engine runs fairly smooth but as I slowly increase the RPM's it starts surging around 2700 RPM. To be more descriptive, it will run at the regular rpm than drop down in RPMs violently, then right back up to the regular rpm. Each drop is about 1 second long, and even when I increase the throttle it won't let me get past this surging point.
    It seems like it may be an ECM issue, or maybe fuel pump. Does this ring a bell for anyone?
    Thanks
    if con is the opposite of pro, is congress the opposite of progress???
  • Mamigacz
    • Oct 2012
    • 118
    • Sheboygan Falls, WI
    • 1986 Ski Centurion concourse skier
    Sounds suspiciously like its starving for gas. Is there anyway you could rig a fuel pressure gauge to see if the pressure drops when the symptoms happen? The gauge would need to be visible by you or a passenger while the boat was moving.
    Unless, you can get it to act up in neutral? Does it only happen under load?
    I'm assuming you have no engine codes, right?
    • bhectus
      • Sep 2010
      • 283
      • Gainesville, FL
      • '02 Ski Nautique '87 Barefoot Nautique - sold '97 Super Sport - sold '96 SN196-sold '83 2001 sold
      My old '96 did that same exact thing to a tee after I had the heads replaced. Turned out to be a faulty oil pressure sender.
      2002 Ski Nautique 5.7 GM Apex
      • core-rider
        • Feb 2004
        • 1366
        • Huntsville, AL
        • 2003 Black SANTE
        You said you had the engine rebuilt over the Winter... Did they overbore the cylinders? If so read this thread... http://www.planetnautique.com/vb3/sh...ck-in-the-face
        You may have the same problem.
        Jason
        All black 2003 SANTE
        -- Southern Fried --
        • Lewy2001
          • 63
          That 2700rpm sounds like the SLOW (Speed Limiting Operational Warning) or "limp mode" is kicking in.
          There is a separate oil and temp switches that activate this mode on the ECM for the GT40.
