Hoping someone can direct me...
Put 200 in the water for the first time this year yesterday... engine started running hot 200+*.
Checked the thermostat and impeller - obvious problem, Impeller was bad.
Local MC dealer who sold us the parts also sold us new thermo that was Indmar brand.
After changing both the impeller and thermostat, engine still ran at 175*, plus started making a "gurgling" sound.
At first we thought it was pieces of the old impeller, but after checking all the hoses, we found nothing.
After about 6 passes, the "service" and "check engine" lights would flash and the boat would seem to want to go into limp mode, even though the temp gauge was static at 175.
We put the old thermostat back on and the temperature dropped to 160*, but (another symptom) the heater doesn't seem to put out any hot air.
Theory is that the motor is sucking air from somewhere, most likely the strainer at the rear of the engine where the o-ring seems to not be giving a tight seal.
Anyone experience with this or have thoughts?
Thanks in advance.
Thanks in advance.
