Steering issue
  • Alpine331
    • Aug 2013
    • 21
    • Banff, AB
    • 2023 GS20
    Steering issue
    I just got my 2004 SV211 out on the water for the first time this weekend and noticed there is a lot of play in the steering (like 3-4 inches). It doesn't feel stiff so I'm not sure if I need to replace the cable. Does anyone know if there is a way to adjust the 'play' out of the steering?
  • beach
    • Jul 2010
    • 245
    • Alabama
    • 2003 SAN 210
    There's a rectangular bar underneath the helm. That contains the rack and pinion part of the steering. It might be loose and not fully engaging with the gear on the steering column.
    • raymanrox
      • Mar 2013
      • 65
      • raleigh nc
      • 1999 super air
      my 1999 with 400 hrs is the same way. I would love to fix this, makes it hard to pull a rider!
      • jhersey29
        • Nov 2013
        • 330
        • Colorado
        • 1971 Correct Craft Mustang 1988 Ski Nautique 1992 Ski Nautique 1999 Ski Nautique
        Check the steering cable bar and steering cable attachment. https://onedrive.live.com/redir?resi...int=video,.mp4
        Sent from my RM-877_nam_att_205 using Tapatalk
        • Alpine331
          • Aug 2013
          • 21
          • Banff, AB
          • 2023 GS20
          Thanks jhersey29! Great video. I'll check that this weekend.
          Quick question though. How are you accessing the that area? Did you pull up the floor because I can't seem to find it.
          • s_kelley2000
            • 1593
            • Fort Meadow Recevoir
            • Mass
            That is the top side of the rudder so on a v-drive it's under the engine/exhaust. If you have ballast tanks you may need to remove the tank on one side and the engine divider to get to it. I can't remember for sure but I think it might be easier to access from the starboard side.
            Shawn
            2012 Blue Metal Flake SAN 230
            • jhersey29
              • Nov 2013
              • 330
              • Colorado
              Remove the motor cover by opening it up and pulling the 2 holders. On my boat they don't screw in 1999 Nautique.
              Remote the rear seat. On mine you just lift them up and there is an attachment on both sides
              Lift up on the floor board it. Should just lift up. Start lifting at the motor end.
              Mine is a bit older so would bet it's a bit easier to access.
              • Alpine331
                • Aug 2013
                • 21
                • Banff, AB
                • 2023 GS20
                Ok, I'll have a look at it tonight. I'm quickly learning that you have to be a midget with gumby arms to work on these boats!
