Serpentine belt for EX343 in 2012 SANTE 210
  • bandit628
    • Sep 2016
    • 318
    • Southern Illinois
    • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
    Originally posted by MacedayDave View Post
    I know this is a 5 year old thread, but for future reference, a Gates K060620 serpentine belt is a direct replacement for the Correct Craft R066028. I just installed the Gates belt on my 2005 SN196 with EX330 engine. The Gates belt can be found at most local auto parts stores. I purchased mine from Rock Auto for less than $14 (plus shipping).
    Thank you! IMO every little bit helps. We should make a page of boat engine and crossover parts list for easy look up.
    https://powerparts360.com/alternator...64ci-ra097009/
    I just put this aftermarket marine grade alternator on. Fired up and worked fine. $100 instead of $300 OEM. Looks the same to me.
    Sent from my SM-G955U using Tapatalk
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      I just bought this belt and noticed the spec is slightly longer (62 5/8" vs 62 1/4"). Have you had any issues?
      Previous:
      2011 Super Air Nautique 210
      1994 Sport Nautique
      • MacedayDave
        • Oct 2004
        • 70
        • Norris Lake - Andersonville, TN
        • 2005 SN196LE
        The specs for the Gates K060620 are 62.642" Outside Circumference with a 62.08" Effective Length. It has worked perfectly on my EX330 as a replacement for the Correct Craft R066028 belt. I have been running the Gates belt for 2 seasons now!
        • shag
          • 2217
          I bought the gates belt referenced above would not fit my 08, 230 with the excalibur motor - the gates K060620 is a tad short. No matter how much a tried, that belt wasn't going on. I matched up one at auto zone that is the length above - and will test fit later today if I can find time, it also is identical side by side with the PCM 066028 - stretched tight. The part number is DURALAST 625K6. Underneath that number it says 6PK1590. This belt is $16 at my local auto zone.
          • shag
            • 2217
            Just confirming, I just installed the above belt (DURALAST 625K6) and it goes on tight with the tensioner, just like the factory PCM belt, and a drove around and checked it and all is well. This is for my 08 SAN 230 with the 343 excalibur base motor.
            Cheers!
