I have the stargazer installed, it checks fine on the linkage test, but I'm a little confused on the operation of it with the way the throttle is rigged, if I have it installed correctly. If I have the servo mounted correctly, I don't understand how the servo can accelerate the boat as it doesn't appear the servo is able to open the throttle.
This picture is looking at the engine from the starboard side, stern on the left. Keep in mind it is a V-drive. When the throttle is opened the throttle arm is pulled towards the front of the boat.
Looking from the back of the engine towards the front. This is the throttle cable attached to the throttle arm underneath the intake.
Servo mounted so the hatch can close.
Here is the servo throttle cable coming from around the front of the engine attached to the throttle arm.
I understand how once the throttle is manually advanced, the servo can pull it back, but shouldn't it also be able to open the throttle plate?
