Hi guys, weve recently bought a 2003 SANTE.
Having a few problems with the engine at the moment, hopefully someone can shed some light on.
We have 2 lights on the dash as per the pic attached.
When we bought the boat the previous owner said that the small red light would flicker on and off for probably the first 10-15mins of operation untill eveything has warmed up properly. Is this correct? or should the light go off after the boat goes above 1200RPM straight away? Is this small red light specifically for the vdrive?
The large red light from memory has not remained on after startup previously. However yesterday the light remained on and the boat would not run above 2500RPM. (limp mode has activated i assume) the tacho would then flash the message 'reduce RPM see dealer.'
Does this large red light only relate to the engine only(not vdrive)?
Our engine temp was approx 160deg and our oil pressure was approx 40-50psi. as per the display on the tacho and analoge gauges.
After further inspection out of the water we have discovered that the v-drive oil was low. We have now topped up the vdrive and idled the engine on the trailer but the large red light is still on.
Has anyone any ideas or suggestions.
Cheers.
Cheers.
