What is the proper installation procedure for replacing a 1993 closed bow ski nautique, one piece glass-front only, windshield?
RE: 1993 windshield replacement
Pull out the plastic cover at the outer bottom face of the frame all around. Remove the large exposed screws at the trailing edge of the windshield wing pieces. Remove remaining screws (exposed after removing plastic cover) from one of the wings and remove the wing (wing is keyed into the windshield. Remove the screws from the windshield and remove the windshield...the remaining wing will hold it up while you remove the screws. Now remove the last wing in the same manner as the first.
I replaced the front window once befor on 93. I think we pulled only the front section and left the side pieces in place. The window on the boat has a slight curve to it, when you get the glass it is flat. We were really holding our breath as we slowly tweaked/flexed it into place. Fun to "what if" about after the fact..
