RE: Diagnostic tool for -94 TBI engine?
I talked to Mark over at PCM to get the proper spec on fuel pressure and TPS setting. He said 13.5-14 psi for the fuel pressure. I cannot get below 15psi. TPS should be .5 volts. He said my .53 volt setting is fine.
But, most importantly, he said parts are still available for the TB EFI systems including the ECU. I have also heard that PCM has parts for the Pro-Tec ignition systems that they are only selling to customers that have EFI engines as the EFI relies heavily on the Pro-Tec ignition...this includes the coil packs.
