Andrew put it right, the 220 has a fair bit of distance from the outer bolt when the plate is out due to the curve.
I ended up with m8 bolts thru hull, and m6 holding on slider plates, therefore if i ever hit something, it will be the sliding plate thats damaged as that has the smaller screws.
With any luck ours will be fitted by the end of the weekend
Andrew it only took me 8-9 months
Water testing sunday gonna be cold!!!!!!! 11 degrees celcius water, and 9 degrees celcius air temp is the forecast
, but does this cause any damage?
