Gas Tank Size
  • mgswed
    • 137
    • Worcester, MA
    Gas Tank Size
    I have a 94 ski nautique and i have no manuals. Id just like to know what size gas tank I have, and how long one tank of gas should last before filling up? Just knowledge id like to know so i dont get stranded out on the lake. Also what octane should i be running? Thanks for the help.
  • DavidF
    • Sep 2004
    • 611
    • Austin, TX
    RE: Gas Tank Size
    26 (maybe 27) gallons. The other part of your question depends on what engine the boat has and how you are using the boat at the time.
    If you want to verify the capacity, just pull the rear panel from behind the back seat and the tank will have a label on the top listing capacity and other data.
      • 2909
      • Current 2017 GS22
      RE: Gas Tank Size
      I believe a 1994 should run on 89 octane gas, probably burns about 7 gallons per hour.
      • mgswed
        • 137
        • Worcester, MA
        RE: Gas Tank Size
        Thank you both very much for the info.
