Just recently did first oil change in my 2012 210 with the 343 motor. What is normal operating oil pressure at say idle and then what should it go to at 20-25mph? Thanks in advance for any help
Wow really? The gauge on the linc goes up to 80psi and I was idling around 40. The oil level is right at the full marker I guess I'll pull a little out. Thanks
At idle... around 650 rpm's my oil pressure is around 33. Surfing at around 2000 rpm's my oil pressure is around 56.
I have the 450 in my 210. Oil is slightly above full on dip stick. It came that way from the factory.
my 330 idles cold near 60 then a little over 40 after being heated up.
I've never really noticed cruising pressures.
Note the oil suggested by PCM is much more viscous than GM specified for similar highway engines....so the pressures are going to be higher than the rules of thumb.
