ACME 644 on SV211's
  • GAnautique
    • Aug 2005
    • 33
    #31
    Anyone have a suggestion on the best place to buy a new prop?
      • 2909
      • Current 2017 GS22
      #32
      Check the group buy section for a deal through delta. I get mine from www.boarditup. $350 or less shipped.
      • ag4ever
        • 1180
        #33
        My reworked 380 was so noisy after the rework I decided that I would never spend the money on reworking a prop again. Having been around these boats all my life I am a little more particular than the average boater. When I bought my 95SN I told them it needed a new prop, they test drove it 3 times until I finally went out with them and showed them how to tell... On that boat the center tow bar would vibrate like a tuning fork. Changed the prop and it went away.
        The way I figure is at $350 to my door it's really not that expensive to replace instead of repitch (equal to two tankfills). Spending money on repitches/repairs doesn't make as much sense as it used to.
        I guess that all depend on whether you have a good company that can rework a prop. I am in Houston, and exclusivle used Beauman Propellers. They have done an outstanding job, and I think it runs smoother with their reworked prop than a new prop. But then again, they make custom props from scratch for various people, mostly for researchers that are running experiments on how to make more efficient props. I think that gives them an edge, since they see first hand what does and does not help make props better.
        • beamons
          • Jun 2017
          • 379
          • Utah
          #34
          Mikeski - So now years later and it looks like you are still running your 211(for now ) what prop would you say has been the best on your 211?
            • 2909
            • Current 2017 GS22
            #35
            Still running the 644, didn't like the ski wake behind the 1234. I also have an 856 as a spare but have not needed it in 6 years (knock on wood). I actually think it may run out better with the 856 but I have stopped tweaking and decided to be happy with the 644. I grabbed the 856 as a high altitude/spare prop when I saw it pop up on sale used from somebody going to one of the big 15" screws for surfing. The 856 is 1/2" shorter pitch which is just about what I need to get my loaded pig up to peak RPM at WOT.
            • MTRBTR
              • May 2012
              • 485
              • MT
              #36
              I know this is an old thread based on the last two posts, Mikeski did you ever run the 856? I love the way the 644 runs at slalom speed but sure seems slow out of the hole and wonder if it lugs too much with surfing. I have had the 856 on and love the hole shot but at my elevation I am running about 4300 RPMs at slalom speed. What is better for my engine? I want to have the boat for a long time.
              2006 SV 211 (Sold)
              97 Sport Nautique (Sold)
              89 PS 190 (Sold)
              75 MFG (Sold)
                • 2909
                • Current 2017 GS22
                #37
                The best prop for the 211...
                Im unique as somebody who surf’s, wakeboards, Waterski’s @ 34, and barefoots. So my demands range from 10-42mph. Unfortunately the ex330 won’t push a loaded 211 over 38mph or so. The best all around prop I’ve found is the 644, I’m still running that prop. My spare is an 856 but I don’t run it as I don’t want to be bouncing off the rev limit while footing. With the 644 I just tell my driver to bury the throttle for footing.
                • MTRBTR
                  • May 2012
                  • 485
                  • MT
                  #38
                  Thanks Mikeski. Was curious if you had ever had a chance to put your 856 on but it sounds like the 644 is the one for you. I rarely barefoot but usually like to get a few slalom runs in and use the boat much the same as you. One of the lakes I boat on is at 6500’ and it’s the first one I tried the 644 on and it was slow out of the hole. Need to try it at the other lake at 3500 feet and see how much different it is.
                  2006 SV 211 (Sold)
                  89 PS 190 (Sold)
                  75 MFG (Sold)
                  • nhbouch
                    • Aug 2016
                    • 50
                    • Lake Winnisquam
                    • NH
                    • 2019 GS22 2007 SV211
                    #39
                    My .02
                    I swapped my 1235 off of my SV211 because the top speed was barely 40mph (from what I remember). We like to ski (and very occasionally Barefoot) as much as we like to wakeboard/surf and the prop wash / rostertail with the 1235 was not fun as skiing speeds (great out of the hole though). Went with acme 537 and its proved to be just good enough for all 3 events. We just use standard factory ballast and have 5 in the boat typically. I have Excal 330 and my top speed is approx. 41-42ish with the 537. Call Acme and get their opinion as well...
                    • MTRBTR
                      • May 2012
                      • 485
                      • MT
                      #40
                      The 644/645 would have better hole shot than the 536/537 wouldn’t it?
                      2006 SV 211 (Sold)
                      89 PS 190 (Sold)
                      75 MFG (Sold)
                        • 2909
                        • Current 2017 GS22
                        #41
                        I have ran both the 536 and the 644. The 644 has a little better holeshot and better top speed. That 0.25" diameter difference helps it in both areas. I guess if my boat was a little lighter then a 536 might be a better choice but the 644 helps it get a little closer to redline at WOT and utilize the powerband of the engine more effectively.
                        • wake_2001
                          • Jan 2010
                          • 3
                          • FL
                          • 2007 SV-211
                          #42
                          Bringing this one back from the dead to see if anyone has additional insight on the best prop for a 211. I recently picked up an 07 with the 330. Currently have the 645, but I'm getting a steering wheel vibration on takeoff with a rider or any weight. Debating a new prop vs repair. I've got the Go Surf Assist system and mostly foil with no ballast, but will occasionally surf and wakeboard with the stock tanks and wakemakers piggybacks. Also pull younger kids on all the water toys, so sub 25mph are the primary speeds, but I do want to be able slalom on occasion. The 645 seems to get it done, but I wouldn't mind a bit more hole shot. Top end is around 42/43 at 5100ish. Acme recommended the 1235, but based on others experience, I don't think that's the one. 1939 or 537 both are the front runners, but the 1433 may be an option. Any insight is appreciated.
