When pulling the plug in or boat at the end of every weekend I notice there is quite a bit of water standing in the hull under the engine. There is about 2 to 3 inches. I feel like the bilge should be pumping water out if it is this high. Is my bilge possible broke or is this a normal amount to have in the bottom of the boat after a weekend trip?
you should have two pumps,manually is a good test, if they still dont work unhook one, and push button and see what happens, if nothing hook back and unhook the another, still nothing, a short or loose connection some where,but very unlikely , if one works during any of the test the one you unhook is bad,it is causing the good one not to work , keep unhook until you replace the bad one, at least you will have one that works.2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
