electronic key pad issue
  • bigredfig
    • Mar 2012
    • 6
    • Bay City, Tx
    • 2001 Pro Air Natique
    So I have a 2001 Pro Air Nautique and Sunday was the first time the electronic keypad wouldn't work the first time. The green light would come on like it normally does when I put in the pass code. So i gave it some time and it worked. Later tried again and no luck. took the dash off couldn't see any frayed wires. All battery terminals good and no blown breakers. Got it back home and pushing the stop button it started. After that got it to start normally but the started stayed engaged and had to full the kill switch to kill it. Put it in drive and the starter wouldn't stops unless i put it in gear and back on when I shift back to neutral. It only did that once. Sometime it all works and other times nothing else works like blower, bilge or nav lights.
    I personally don't feel that my closest dealer is any help.
    I was think condensation in the key control pad but it seem sealed but I could see the so called computer board from one edge.
    Any ideas what to check next or how to dry out the key pad?
  • s_kelley2000
    • 1595
    • Fort Meadow Recevoir
    • Mass
    Put it in a zip lock back full of rice over night and the rice should adsorb the water. It works for iPhones and it worked for at least one persons keypad on this site. Worth a try before shelling out for a new keypad.
    Shawn
    2012 Blue Metal Flake SAN 230
    • hyparks
      • Feb 2011
      • 302
      • Brownhills, United Kingdom
      • 2001 Super Air 210
      There's been lots of keypad threads on here. They do go bad, corrosion under the micro switches. Although they are heavily sealed you can still get water/condensation in them. I had issues with my auxiliary keypad, that got wet and licked out the start keypad. Thought my start keypad had also gone bad until I disconnected the auxiliary.
      A nice sunny day usually does the trick or disconnect and remove the keypad and dry it in the house.
      Hope this helps
      Sent from my HTC One using Tapatalk 2
      Current
      2001 SAN 210, GT40
      Previous
      1994 Mastercraft Pro Star 190
