First weekend out with the Fam on the new boat. Found that battery switch was left in "both" all winter. 2 dead batteries. Replaced one battery but I get no power to dash. Nothing. I don't put in the start code, hit start and get nothing. Boat is still on trailer if that makes any difference. I have checked all circuit breakers I can find including 50A on engine. I'm hoping its just something I missed. Under the steering wheel (way under) are two rows of lights(?). None are on. If they are breakers they are not popped.
Does Horn work without code?
which battery is 1 and which is 2?
if I set to "both" an only have 1 battery is that going to work?
help!
thanks
help!
thanks
made things worse.
