Creeping electrical problems
  • Tpmc
    • Jun 2012
    • 10
    • Birmingham,al
    • 2005 sante
    About half way through last season I noticed my volt gauge would only work about half the time (no reading/no backlight) by the end of the season it never worked. After getting the boat back from the dealer last weekend it appears my temp gauge is heading in the same direction. The dealer said the volt gauge was just stuck, and that it was getting voltage I just needed to get a knew gauge. Is this a gauge issue or a bigger one?
    Thanks,
    Patrick
  • swankster
    • Aug 2010
    • 1052
    • DFW, TX
    Have you noticed any problems with the batteries? Also, what make, model and engine do you have?
    2010 SANTE 230 343 (280hrs)
    • Tpmc
      • Jun 2012
      • 10
      • Birmingham,al
      • 2005 sante
      Haven't noticed any problems with the batteries. It's a 2005 Sante w/ the 6.0 PCM I believe.
      • Quinner
        • 2246
        • Correct Crafts
        Check your connections at the Gateway Box, ensure they are fully inserted and making a clean connection.
