de winterizing my 216
  • Rharness
    • May 2012
    • 38
    • Jonesboro ar
    • 2003 air nautique 216
    This is the 3rd summer to use boat and last 2 I paid someone to change the impellor, oil, and check everything. I am going up early and want to do it myself. I am mechanically inclined, my question is what impellor should i get? they are 30 to 50$ at nautique parts, and I want to replace my belt (started squeeking last year) and really dont know which to get. do i get the serpentine? I have a 03 air nautique 216 with the 5.7 330 hp. Thanks in advance. Anything else i need to do. I am going to change plugs, charge batteries, change impellor, belt, and oil.
  • Quinner
    • 2246
    • Correct Crafts
    Hopefully the trans and motor oil/filter was changed at winterizing, if so u don't need to do it again. If you are due for plugs you may want to replace the cap and rotor as well. When was the FCC filter changed last? If more then a couple seasons old change that as well. Impeller does not need to be replaced every year, inspect it, if it looks OK use, just always have a spare on hand. 03' Excalibur may use V-Belts, post a pic and we can tell you for sure, otherwise if it's a serpentine, just one belt to change. Who winterized the boat? Are all the drain plugs replaced? Would check them all regardless. If your rudder has a Zerk fitting, hit that with some grease.
    • Rharness
      • May 2012
      • 38
      • Jonesboro ar
      It starts and runs good. Not sure when plug were changed. Yea I always check drain plugs. My storage place winterized it. I change oil at beginning of summer. I like to be hands on on all toys and vehicles but boat being 2 hrs away puts a strain on it. I'm building a house and shop so end of the year my problem will be solved.
      • Rharness
        • May 2012
        • 38
        • Jonesboro ar
        I only have round 300 hours on it.
        • chris196
          • Mar 2007
          • 223
          Are you saying you changed the oil at the beginning of last summer and then whoever winterized it changed it again in the fall? If so, then no need to change the oil again as already mentioned.
          In general, if you aren't using your boat enough to warrant an oil change during the summer season, then change it in the fall when winterizing because dirty oil has built up impurities and acid that you don't want sitting in a dormant engine. Change in the fall, hop in and go in the spring (assuming everything else is in working order).
          • Rharness
            • May 2012
            • 38
            • Jonesboro ar
            Thanks. I'll start changing in fall. And I only put bout 30-40 hours on it a season
            • AirTool
              • 4049
              • Katy, Texas
              If you have the serp belt, read this tread (all of it...it improves along the way). The info starts w/my post #2.
              Order your parts from www.nautiqueparts.com and use code PND
              http://www.planetnautique.com/vb3/sh...-PCM-Excalibur
              • Rharness
                • May 2012
                • 38
                • Jonesboro ar
                Thank you!
                • Rharness
                  • May 2012
                  • 38
                  • Jonesboro ar
                  Thanks guys. Changed oil, Impellor, checked belts. And put a heck of a cleaning. Earliest I've every done this and she'd a beauty!
