If your impeller shredded, make sure to remove the t-state housing and check for blockage. Interestingly, though, on the GT-40, impeller bits seem to float upstream. Back flush the hoses past the raw water pump and check the pump side of the screen on the transmission cooler. Mark that pump housing orientation, make sure you get the little plate set up right so the screws are going through all of the holes, i.e., it's not just sandwiched in there, make absolutely sure you have your belts reinstalled properly and tensioned to about 1/4" of travel. Finally, as mentioned, check the sea strainer to make sure you aren't sucking air there.
Even if you catch it early, if you get enough heat in the pump, the impeller vanes can get hot enough to melt. You let it sit while you try to work out the problem, then you restart, and bits of the vanes get ripped off because they were stuck to the housing. Ask me how I know.
