Hi guys I am in the process of planning out the build for the ballast system on my 1999 Super Sport. I have already read through a lot of great threads on other builds on this site but I wanted a little more information on running a 4 bag system with 3 pumps. This boat did not come from the factory with a ballast system so I will be starting from scratch. I already have 750s in the rear lockers that I fill partially for wakeboarding, rear seat sack in the belly locker and the bow bag under the bow seats. I was filling all of those bags manually this past summer. I know the best solution would be to add 4 pumps so each bag could be filled and emptied independently but in an effort to save some money and install time I was thinking of going with 3 pumps for the 4 bags but I am not totally against adding 4 pumps. My plan was to add 3 through hulls on the bottom for each pump, add two new vent lines for the rear bags and mirror the through hulls for the bilge outlets on the port side. For the belly and bow bags I was thinking of putting in a switchable Y fitting so I could divert the water to/from the bow or belly depending on which one I wanted to fill/empty. For the vent line I was planning to use the "cooler" drain for at least one of the front bags and I was wondering if it would be possible to tie the vent lines together since these bags would be filling and emptying at separate times? If not, where is the belly vent outlet located on the later SS/SANs that came with belly ballast as I would like to keep it looking as close to factory as possible even though belly ballast was not offered in 1999.
I know another option is to have the belly sac overflow into the bow bag and I would only need 1 vent line but I am thinking I would like to be able to fill and empty these bags independently. But the more I think about it the more that doesn’t seem necessary as I can’t think of any scenarios where I would want the belly less full than the bow but I can think of a few where I would want the bow empty but some water in the belly which would still be easily doable with the overflow setup whether filling or emptying. Any thoughts on these issues would be appreciated. I’m still a couple months away from pulling out the hole saw but just trying to get my plan in order ahead of time so I can start ordering parts.
