Could be a step by step has been posted before--I didn't see one on a search. Getting these tanks out took some effort, so I figure it's worth putting this up to help out others.
I've used the 400lb Fat Sac v-drive sacks in a piggyback configuration. This has been a great setup, but I decided to remove the tanks and go with 750lb sacks only to give us a little more storage room all of our winter riding gear.
PM me if you want the v-drive sacks--they show normal wear/tear, but are in excellent condition...I'll put an ad up in the classifieds, but $125 shipped works for me.
Jeff--if this type of thing has been posted before, feel free to delete:
1. Remove the "false floor" covering the tanks--these just pull out
2. Remove the bracket holding the tank in place--near the front of the tank on the inboard side. Three bolts.
3. Remove the hose clamps on the intake and vent hose and pull the hoses off. If you've removed the bracket in step 2, you can slide the tank forward to get better access
4. Remove the brass intake and vent elbows--I was able to do this without tools. This is important as these fittings can scratch things up when you pull the tanks out
5. Remove the water level sender unit. This is critical. I didn't do this on one tank and it ended up chipping some gel coat because it becomes the critical clearance item even though it doesn't look like it at the start....but the tank gets compressed a bit when pulling it out and this sender then sticks up and will catch your fiberglass. Learn from my mistake!
6. In the cockpit, ( a ) move the rear seat out of the way so it doesn't get damaged, ( b ) remove the horizontal portion of the rear side seats....remove the gas shocks from the bracket. Then you can remove the bracket from the seat (6 screws each) or the bracket from the boat. I removed the bracket from the seat because that looked a little easier.
7. Leave the rear vertical portion of the side seats in the open position
8. Turn the tank on its side so the bottom is facing the center of the boat. Notice the square bulge at the bottom rear of the tank...you'll come to hate this part of the tank
9. Slide the tank forward into the space under the side seat. Lift the front of the tank up so it is now standing on up...the bottom of the tank is facing the center of the boat, the front of the tank is pointing straight up, and the tank is resting on its rear panel.
10. If you try to lift the tank out at this point, you'll find it won't fit through the opening...the square bulge near the rear of the tank makes it too wide
11. Grease up the rear of the tank where it's going to rub against the seat base as you pull the tank out. The more grease the better. The tank is going to move around, so get everything lower than the seat base.
12. You're going to need to push against the front of the tank while prying the tank up through the opening in the seat base. The tank has to be squeezed down about 1/2-3/4 inch. I did this by draping a towel over the seat base along the bottom side of the tank and using a wide pry bar and some narrow/long plywood pieces to leverage against the tank. This, of course, pushes the top of the tank tight against the seat base on the opposite side (...hence the grease). The seat base can cut into the top of the tank a bit and catch on it. If you haven't greased well, you'll have this problem. If this happens, drop the tank back down, sand/file down the ridges you've created, grease up and start again.
13. While one person is prying as mentioned above, another person can get in the rear compartment and use a long pry bar to get under the tank and push it up through the hole. I put plywood on the floor to protect it and also had some wood blocks to push under the pry bar to keep a good (horizontal) angle on the bar as the tank was pushed up.
14. This isn't easy and you have to be careful you don't damage the boat, but if you stick with it, the tank will eventually squeeze through the opening in the seat base.
15. When finished, have a beer.
