Hi folks - have used the term 'chine lock' but not sure what it really is.
Our 206 has developed a nasty habit of lurching to one side and holding that edge if the weight is not distributed properly in the boat...feels like it is going to tip over and then slews around at the back when you back off. For example, if you have the driver on one side and two on the observers seat (one in the middle and one on the side) and then someone sits next to the engine box or on the gunnel on the observers side then the boat rides low on that side and high on the drivers side, which I understand, but then at some point it will lurch up on the observers edge and you have to back off otherwise it feels like the boat is going to tip over and even then, when backing off, it is still pretty scary.
I know boats don't ride well if the weight is not distributed properly but this is scary stuff and it doesn't happen in other friends boats.
Any thoughts?? Anybody else have the same experience?
