Perfect pass confusion
  • jmo
    • Mar 2006
    • 734
    • MA
    Hey Guys,
    So I'm trying to make use of the Digital Perfect Pass my 196 has, and when I put it into basic slalom mode and toggle to run 32.4, once it engages the boat according to the digital speedo on PP is around 30.4? How can that be as I would have thought its referencing the speed its displaying? No matter which speed I toggle it to in the 28-36 range, its running about 2 mph below where its supposed to. Any ideas of how I correct it? Do I need to use the rpm offset feature?
    I have read the manual several times and its still not clear to me what I need to do.
    Thanks,
    JMO
    2018 Ski Nautique 200 TE, H6
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    First of all try a system reset to re calibrate. If still down you can adjust the speed reading, but this is done in wakeboard mode. It tells you how to do it on page 7 in the wakeboard user manual for perfect pass. If you have digital pro you can change setting to wakeboard pro mode, alter speed reading then change back to digital pro.
    Hope this helps
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
    • AirTool
      • 4049
      • Katy, Texas
      I thought that version actually switched over to rpm control (after 26 mph) even though it shows speed. First step is to calibrate it with the GPS. If that fails, reset it and start from scratch with the "settings". ....after calibrating again of course.
      • Bri93SN
        • Jan 2012
        • 29
        • Boston
        • 1993 Ski Nautique Standard
        Yup, I would say a calibration issue. Calibrating syncs up the engine RPM with the actual boat speed. I believe the higher (slalom) speed settings go off of Engine RPM, so Speed to RPM has to be synched ahead of time.
        This compensates for variables such as propeller pitch etc.
          • 2908
          turn the PP on and put it in slalom mode set to the speed you want, wait 10 seconds
          push the menu key until the arrow highlights black then push the down arrow
          raise the RPMs about 180-200, check result
          (going off memory so I may have missed a step but you get the idea)
          I do this a few times each year since I sometimes like to go a little faster and sometimes like to go a little slower. In slalom mode it only allows for 2mph changes which I find annoying.
          You may also want to check the speed with a GPS, I use a free speedo calibrate app on my iphone
