Hello,
Our 1994 GT 40 (fuel injection/EFI) will not start, no sputtering whatsoever. Unlike usual, when ignition is on I do NOT hear low pressure fuel pump priming system. I hear an initial click but no priming/pumping. At fuel pressure gauge check-valve on fuel injector rail there is no evidence of pressure or fuel. When I crank it over I have visual spark at #1 spark plug. When starting fluid shot into air cleaner engine sputters/wants to fire unlike cranking without SF.
1) Is an inoperative low pressure fuel pump sufficient reason for engine not to start at all?
2) What is the best way to troubleshoot the LPFP? Should I start by replacing the relays? What is the procedure for testing if the LPFP is getting power?
3) I only have access to the boat on weekends. What parts/specialty tools do you suggest I have with me next weekend?
Please respond with as much or as little detail as you wish. I appreciate any guidance,
Thanks,
Jackson Minasian
Thanks,
Jackson Minasian
