1993 Nautique Speed question
  • JasonS
    • Jul 2012
    • 13
    • Batesville, AR
    • 1993 closed bow
    I bought my first nautique last summer and am loving it. I have a concern about the top speed and RPM's. It has the lower horsepower 351 in it and it top speed is only 35.5 MPH. The RPM's are around 3600. Is that right? If it is not what do I need to do to fix it? If it is right what do I need to do to increase my speed since I am 250 lbs. and like to barefoot, I need a little more speed.
    Thanks ahead of time
    Jason Skelton
  • mdvalant
    • Jan 2010
    • 155
    • IA
    • '90 Ski Nautique '00 Sport Nautique 75th
    you should be in the 4400-4600 range. Do you know what prop you have on it?
    • Full-Force
      • Sep 2011
      • 87
      • Spartanburg, SC
      • 1996 Ski Nautique 176
      I think I have the lower output 351 in mine as well but my boat will do 46 - 47 mph gps verified. Not sure what prop I have but its a 4 blade prop, a 1.23:1 transmission and the boat is a SN 176.
      • jdmoore59
        • Oct 2011
        • 40
        • Yazoo City Mississippi
        • Current: 2001 Super Sport Previous: 1998 Ski Nautique, Green/Zephyr/Natural, 5.8L H.O
        Your secondary throttle plates may not be opening. Are you any good with carbs?
        The lake is calling and I must go.
        • TRBenj
          • 1683
          • NWCT
          No, that performance is not typical- you have an issue you need to correct. I would recommend surfing over to Correctcraftfan.com for some better advice.
          1990 Ski Nautique
          NWCT
          • JasonS
            • Jul 2012
            • 13
            • Batesville, AR
            • 1993 closed bow
            No I do not but will look.
            • JasonS
              • Jul 2012
              • 13
              • Batesville, AR
              • 1993 closed bow
              Good enough to have someone else look at it!!!!
              • AirTool
                • 4049
                • Katy, Texas
                What !?
                  • 2908
                  check the initial timing and distributor advance mechanism to make sure it's working. Even with primaries only a 176 with a 351 should probably reach at least 40 MPH?
                  • TRBenj
                    • 1683
                    • NWCT
                    Originally posted by AirTool View Post
                    What !?
                    Did I stutter?
                    1990 Ski Nautique
                    NWCT
                    • jdmoore59
                      • Oct 2011
                      • 40
                      I guess we should all follow the thread on another site.
                      http://www.correctcraftfan.com/forum...e-speed-issues
                      • AirTool
                        • 4049
                        • Katy, Texas
                        Blasphemy ! I am loyal to this site !!!
                        • JasonS
                          • Jul 2012
                          • 13
                          • Batesville, AR
                          • 1993 closed bow
                          I asked the question on both sites to get information about a problem I dont know how to fix. I dont care who answers my questions, I just need some answers because I dont know anything about what is wrong.
                          Since I posted other info on the other site, I will post it here also.
                          I have since done some checking and the secondary plates DO open up if I force them open manually(that is without the engine running). It was suggested on another site to water test it, by that I mean have a driver run the throttle up and manually open the secondaries to see if the speed or RPM's increase. If it does, it was suggested that it may be the diaphragm needs replacing.
                          Any other suggestions now that you have more info.
                          • shag
                            • 2217
                            So wait, you've had it to 46-47 GPS? or it is going that fast now on GPS and just not on the gauge... Sorry if I got confused. It does sound like what the previous posters are saying though. The vacuum secondaries are not opening, something happened with the timing advance, or someone switched props on you (just kidding). Most likely fuel related IMO.
                            Good luck on either site! lol
                            • JasonS
                              • Jul 2012
                              • 13
                              • Batesville, AR
                              • 1993 closed bow
                              Mine will only run 35.5 MPH at around 3600-3800 RPM.
