I'd appreciate any tips, advice, or links on this job. I've got no choice but to do it myself unless i want my local nautique dealer to shake me down and take 7 weeks to fix it like last time. Besides, I believe this is just one of those things you should know how to do yourself if you do your own maintenance. You can save yourself some weekends, and lots of $$$. Theres only a dozen or so bolts, and at this point I think the engine alignment is going to be the easy part.
I've just removed the 8 coupler bolts which probably took 15 minutes a bolt. You can't put a socket on them, and its done a 1/4 turn at a time with an open ended wrench on one end. Its also helpful to be able to bend yourself into a pretzel. What i need to know now is the sequence in which to do things. With the coupler unbolted, it still shows no signs of wanting to separate even a fraction. My common sense is telling me the strut is holding things in place and i'm tempted to unbolt it, remove it, and then start tapping the shaft. Or should i spin the shaft from the prop? See what i mean.....I better check here first.
Would anybody have a link to the process in a service manual? I've searched and couldn't find any good DIY articles. I will try and take pics along the way and put something together.
