I was having an issue in my ballast system where the sacks / tanks were losing water. Every couple of sets, I was having to put more water in. After some investigation, I decided that the issue could be that the older yellow impellers still in my pumps were letting the water drain back out. I bought new green impellers and swapped them out. Problem went away. So just want to share my expereince that the green impellers prevent backflow much better than the yellow ones.
On another note, I had heard that the initial design of these pumps used black impellers, then the yellow ones were the 2nd generation then the green is current. On my center tank pump, I have a blue impeller. It may be bonded/glued to the shaft. When i was trying to remove it, it would not slip from the shaft and I ended up leaving it in there for the moment. Anybody know what the blue impellers were?
