1993 SNOB seat removal -Help
  • johnjmurray
    • Jun 2007
    • 37
    • Indianapolis, IN
    I need to remove the front bow seating in my 93. This is play pen style open bow, with a bottom pull out cushion and seat backing wraps around the interior.
    I can get to the screws, stearn side but not sure how to get the bow/front part of the seat off. Unless I starting yanking the heck out of it.
  • areford
    • Aug 2009
    • 34
    • Fayetteville, GA
    • 1993 Sport Nautique
    On mine there are 2 screws under the observer seat, 2 behind the kick panel, and then 2 under the front center, behind the vinyl logo panel. Peel it back and hunt through the foam and you will probably need a 4" Philips extension and drill to remove them. The unit then lifts straight up as their are also 2 tabs which are used to seat the unit and hold it at the correct height. Don't yank it out or you will be kicking yourself later, good luck!
    1993 Sport Nautique
    - New Interior - Copycat Covers
    - Ramlin Trailer overhaul
    - Buff and polish oxidated gel coat
    - Exhaust repair
    - Holley rebuild
    Previous: 1980 Mastercraft - Lake Lanier. GA
    • johnjmurray
      • Jun 2007
      • 37
      • Indianapolis, IN
      Thanks areford, I'll give it a look over the 4th. Much appreciated.
