I have a 91 Nautique with low hours. Unfortunately I overheated it driving when the empeller went out for a few minutes. I have replaced the impeller but the engine management system goes into limp mode once the engine is running for 4 to 5 minutes a cruise speed, will reset when turned off and on. Is there a reset to this?
Fuel injected? I wasn't aware they were using FI that year. I would say disconnect the negative battery cable for 15 minutes. In cars that will normally reset ECM
The Protec ignition/engine management system was available starting in 1991. It was optionally paired with (throttle body) EFI in 1994-1995. Otherwise, it came on carb'd engines.Originally posted by Full-Force View PostFuel injected? I wasn't aware they were using FI that year.1990 Ski Nautique
NWCT
What does your temp/oil pressure gauge say when the issue occurs? Any possibility that broken water pump impeller ribs have made it past the housing and are clogging the system further downstream causing it to overheat? If the impeller wasn't intact when you removed it this is a very real possibility.
The Protec system has sensors and will go into limp mode if there is an issue. Certainly could be a bad sensor, but I would think that would show up on the gauges as well. If the gauges are reading ok I'd think the Protec itself might be failing. Typical with boats from this era.
