Has anyone used a Dual Action/Random Orbital polisher such as a Porter Cable 7424 or Meguiars G110v2 on their Nautique with foam pads when waxing & polishing their boat?
Can they be used on top of the decals/stickers/pin-stripe, or do those areas have to be done by hand?
I've been waxing my Nauitique by hand of the past 5 years...done a really good job of maintaining the tops & sides, however I've let the underside slide a bit. I was putting on some Collinite 920/840 fiberglass cleaner this weekend by hand (only did a small portion) while the boat was out of the water and it was evident I need to pay a little better attention to the underside. I'm contemplating purchasing a DA/RO polisher to see if I can make the cleaning process a bit easier/faster, but I'm also a bit worried about how the sticker/decals would deal with a foam pad.
On a prior inboard/outboard I used something on the end of a drill ~10 years ago, and I was wondering if things have improved since then, or if sticker/decal areas still require hand polishing & waxing.
Also, do the pads have to be cleaned while putting on a fiberglass cleaner such as Collinite 920? The rag was getting quite dirty from the muddy water that has attached itself to the bottom side of the boat.
