Cleaning out Zebra Mussels
  • TX-Foilhead
    • Mar 2009
    • 351
    • Kingsland TX
    Questions for those of you who have to deal with Zebra Mussels.
    This weekend we are out of town on a lake where they have recently found Zebra Mussels. Its far from home where we do not have to deal with that sort of thing and I've already taken precautions and unhooked the heater. We only run lead ballast so no issues there and the boat can stay on the trailer through next weekend for cleaning and detailing so my trailer should be clean by the time I return the boat to the slip. What I don't know is how to go about being sure the motor and Vdrive are cleaned out. I don't have a problem winterizing everything temporarily when we get home, but am wondering if there is anything more or different I should do to be sure it is clean.
    I have a small lawn maintenece business that supports my foiling and boat stereo addiction so I want to be absolutely sure that I don't bring those things back since they would be a nightmare to deal with in my irrigation systems.
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    Up here in Washington, the dept. of fish and wildlife will perform an inspection, maybe you can locate a similar service. Its classified as an invasive aquatic species and is a major cause of damage to agriculture and industry, as you know. Stiff penalties and fines exist up here, so do take precautions!
    Next, I believe the sterilization process involves high pressure steam application to the running surfaces and underwater gear, intakes and bilges.
    Contact your fish and game folks for the needed resources.
    • EchoLodge
      • Jan 2004
      • 616
      • Huntington Beach, CA
      • 99 Super Sport
      I have had to have my boat inspected a few times when taking it to Powell. If the boat has been out of the water for 21 days then you are good to go. If they find any water in you bilge or check your hull and anchor equipment and the feel like sandpaper then they pressure wash with 140 degree water. A buddy had them fill his ballast with 140 degree water and he said it killed his pump.
      http://www.google.com/url?sa=t&sourc...wXK7TP6n1vll-Q
      url?sa=t&source=web&cd=4&ved=0CF4QFjAD&url=http%3A %2F%2F100thmeridian.org%2FDocuments%2FTalking%2520 Points%2520Regarding%2520Western%2520Quagga%2520Mu ssels.pdf&ei=Cpu3T5PIIfPjsQLVpPyKDA&usg=AFQjCNGYMi lD7ER8DP9DnHUsufQIUq7RBg&sig2=jH2_d4ImZ9bqPjCn7Wgs RA
      Tapatalk from my ICS Epic 4G
      sigpic
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        http://texasinvasives.org/resources/..._checklist.pdf
        http://www.texasinvasives.org/action...php?alert_id=2
