Hi again everyone.
I did something a bit foolish really. Whilst doing some rewiring on my dash pod I removed some wires from the back of the gushes.
One is the link from the perfect pass paddle wheel to my speedometer. The photo with the green and white wire. I believe they are signal and ground but which is which?
Also the photo with the red, black and white wires. These come from the small knob underneath the dash. I think this alters the needle position on the speedometer. But again which wire is which?
Finally the last photo has a grey wire with a connector on the end that was never connected to anything. The one I am pointing too. There is also a black wire which connects to the rev counter. Both these wires go into the black sheath you can see on the left of the photo. This then goes to the rpm connection on the perfect pass module. Like I said this grey wire was not connected and can see no where it should connect to. Just wondered if it should be?
Thanks guys.
James
Sent from my HTC Desire HD A9191 using Tapatalk
Thanks guys.
James
