I am trying to find information about installing a heated shower on my closed loop system. I have attempted to do research and have found very little. What are my options? Can I divert the hot water from after the heat exchange or water from my heat? Any input would be appreciated!
Water from the heater would not be good, that would just drain the engines cooling system.
I am not sure if the water exiting the heat exchanger is hot enough to be useful. Also taking water from there will result in less water cooling the exhaust system.
You might be able to get warmer water from the end of the exhaust manifold not hooked up to the water inlet to the exhaust manifold, but this also reduces the amount of cooling water going out the exhaust.
