2002 SAN GT40 Winterization -- Drain Plug Locations
  • SoldTheBayliner
    • Aug 2011
    • 170
    • Northern California
    • 2000 Super Air Nautique
    #31
    It will hit sub zero a few times throughout the winter. At least a week or two where the HIGH temp will be below freezing.
    • jmo
      • Mar 2006
      • 734
      • MA
      #32
      That's colder than I would have guessed - cycle the AF through the system and pull the impeller afterwards, wash it off and store separately. The extra hour or two of work is well worth the piece of mind that your boat is set up to handle whatever cold temps come your way. Plus, this way all the plugs are in place so in the Spring the only thing to do is put the impeller back in.
      2018 Ski Nautique 200 TE, H6
      • SoldTheBayliner
        • Aug 2011
        • 170
        #33
        Yeah people forget we have these mountain things in CA... think Tahoe. I'm at 4500 feet. I will do the AF thing... looking at it, the water flows through the V-drive before it even gets to the engine, so I'm sure the V drive will get filled with AF.
        Thanks...
        • cragginshred
          • Aug 2011
          • 45
          • Tuolumne, Ca.
          #34
          On my 95 SN with the GT 40, the 2 on the rear of the manifold will not come out, they are in tight and have a plumbers type tape on them. All other plugs have been drained. Is it normal to have to use a socket wrench with out the socket to unscrew the manifold plugs, and should they be super tight??
            #35
            The exhaust manifold plugs may have a 1/2 square drive. Yes, they can be tight.
            • pdxCC
              • Aug 2009
              • 143
              • Portland, Oregon
              • Current -> 01' Air Nautique Previous - 93' Ski Nautique
              #36
              Hey guys - I have a question on the GT-40 Direct Drive transmission cooler. How does it work? Pressure differential I would assume. If I ran Antifreeze into the block would it have gotten to the tranny too? What are your thoughts?
              ____________________________________________
              Current Boat --> 01' Air Nautique (April 12' to current!)
              Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
                #37
                It depends on the actual location of the transmission cooler. I think it was relocated about every six months.
                On my 1997 Ski Nautique, I take the bottom hose off the raw water pump, and hold it in the bottom of the bilge, and the water runs out, because the transmission cooler is slightly higher than that. You can also blow air backwards, with the strainer cup off the strainer body.
                Do not get antifreeze in the strainer cup, it attacks the plastic.
                How does the transmission cooler work? There is a bunch of small pipes inside the body of the cooler that the water flows through, and the transmission oil flows on the outside of the small pipes. Or maybe the transmission oil goes through the pipes, and the water flows on the outside of them.
                • pdxCC
                  • Aug 2009
                  • 143
                  • Portland, Oregon
                  #38
                  Thanks Dan. I think I am good. I was reading this thread and became concerned that water was circulated to the tranny. Glad to hear that my understanding is correct that it is the oil that circulates.
                  • 2001SAN
                    • Apr 2012
                    • 203
                    • Ireland
                    • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
                    #39
                    Great thread. Just what I was looking for.
                    Thanks.
                    • Kejsj30
                      • Apr 2011
                      • 3
                      • Milwaukee, WI
                      #40
                      I did this today.
                      I'm a little confused on how you drain the water from the heater core?
                      • Kejsj30
                        • Apr 2011
                        • 3
                        • Milwaukee, WI
                        #41
                        Never mind I did some more searching and found where the heater hose is connected to one of the drains on the block, which I did pull and drain into the bilge.
                        Looks like I should blow some air to get all the water out of the heater core though.
                        Thanks!
                        • goldfisch
                          • Apr 2015
                          • 29
                          • elkhart indiana
                          • 2001 sante
                          #42
                          Hey guys when I pulled both plugs on my v drive shown in pic on page 1 nothing came out. should I worry about this. Or cycle antifreeze threw I want to finish tonight. thanks
                          • homer12
                            • Feb 2016
                            • 584
                            • Indianapolis, IN
                            • 2004 SV211 TE
                            #43
                            Did you pull the water hoses off that go to the vdrive? Without doing that I'm not sure how else water would have been able to get out of the vdrive. I did my vdrive last of the drains and a significant amount of water came out
                            • goldfisch
                              • Apr 2015
                              • 29
                              • elkhart indiana
                              • 2001 sante
                              #44
                              I didn't pull the hoses off I'll do that when I get home. I pulled a hose that went to I believe was to trans cooler
                              • goldfisch
                                • Apr 2015
                                • 29
                                • elkhart indiana
                                • 2001 sante
                                #45
                                My next ? Is if I circulate antifreeze threw the system will it run threw the v drive to?
