Any ideas or seen this before?
PP SG in my 97 Nautique. I was pulling my wife skiing this afternoon (Not using PP control) and then we swam off the platform with the engine off and the stereo on for about 5 min. When I fired the boat back up, the PP display had the backlight on, no display, and the alarm sustains a constant beep.
So far, I have done the following:
1) Checked the connections on the module to make sure they are all tight
2) Checked the fuse to make sure in the holder well and clean
3) Pulled the gauge out and looked through the back hole to make sure all those wires are still soldered to the terminals
4) Pulled the main power wires out to do a full power down reset
5) Done the on/off + mode button reset on startup
6) Turned on all accessory switches, lights, etc to give the most paths back to ground in case it is a grounding issue
What I have planned next:
1) Connect the ground straight to the battery to try and prove a low voltage issue 100%
2) contact PP for any help
