"normal" oil pressure?
  • skinnytick
    • Sep 2008
    • 25
    okay guys, what would you say is "normal" oil pressure - 330 excalibur engine , 2005 year 196 Ski Nautique ??
    Do not assume your oil pressure gauge is accurate. If you are really worried, you need to have a mechanic put an accurate calibrated mechanical gauge on the engine.
    General rule of thumb is you need 10 psi per thousand RPM. Keep in mind it is not oil pressure that lubricates the engine, it is oil flow.
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      Ditto... It would really probably be better to just have an idiot light. Red if there is no pressure. hehe. Leave the gauge out of it.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • AirTool
        • 4049
        • Katy, Texas
        You guys are probably jumping to conclusions. He is probably worried his pressure is too high.
        With the 15w40 PCM recommends, my pressure runs 60+ plus cold and rarely if ever falls below 40. In my 99 Tahoe with the same engine and 5w30, the pressure is much less and in line with the 10/1000 rule. I'm sure oil temp is much hotter as well.
        About every 15 to 20 hours I wipe out the top of the remote filter...a few moles of oil must seep out when the pressure is high at startup. I don't know the design pressure of the canister filter...but I know it ain't much more than my high pressure.
        ps - not sure I agree much with the flow not pressure comment. Pressure is key to make the hydrodynamic bearings work. Flow carries the heat away.
        • skinnytick
          • Sep 2008
          • 25
          great, thanks. Boat runs between 35-40psi on tickover, maybe gets to 45 @2000rpm or so, so looks about right then! my old Ford engined 190 used to run at about 50-60 pretty much all day
          • surroundsound64
            • Jul 2005
            • 2147
            • Longview, TX
            The 10/1000 is a minimum and a rule of thumb. Oil pressure too high is just as harmful as too low. Cold engine will have higher pressures.
            Your engine sounds fine.
            2018 SAN 230
            1981 Ski Nautique
            Sold - 2000 SAN
