Ok. I'm sure this has been covered a dozen times but my mechanic who winterized my boat insists upon 30 weight oil. He says that he has seen engine failures using the mult-weight oil. Problem is, the manual for my 2003 PCM Excalibur says 15W-40 for operation above 50 degrees. What should I do? Do I trust my mechanic who has been working on inboards for 30 plus years or do I put the recommended oil in. BTW, I always put 30 weight oil in my GT-40 with no problems. (I think that was recommended by PCM.)
Thanks for your help.
