Ballast puppies off 03 SAN touch pad
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    I have not been able to get into storage for some time. I am traveling for work too much right now. Its killing me... I will try to get some pictures of what I did as soon as I get there, but probably not going to be soon...
    Sorry.
    • thedude
      • Apr 2007
      • 451
      • SW PA
      Quick question for you guys; I have my Johnson pumps wired according to the schematic above. It works great except for when I am filling the pumps while the boat is running and then shut a pump off it will cut all power to the dash. It trips then comes back online but the power trip will cut out the perfect pass, speedo, and gauges. Instead of grounding to the pump relays to the battery, would it be worth grounding to the engine or frame? Or should I install a capacitor to lessen the shock to the electrical system? Any tips would be great.
      Thanks guys!
      • jlembas
        • Jun 2005
        • 2
        • Chandler, AZ
        You need to install shunt diodes across your relays. That will stop your power issues. We had to do the same thing on a similar boat.
