Alright, so the boat is a fairly new to me 02 SANTE. In past trips on the water the steering felt a little tight when turning all the way right and all the way left. As if it was just getting "sticky" when turned all the way. However normal steering was simple two finger movement.
Well last night after an evening set I'm putting the boat back on the trailer and the steering suddenly gets very stiff. Two hands turning stiff. I bail from my line to the trailer and take make a circle playing with it, then suddenly the steering loosens back to what it felt like before, nice and two finger easy.
The boat only has 200 hrs on it and most every boat I've had that the cable needed replacing the steering gradually got worse over time. The low hours and age of the boat make me think there may be some lube issues or just gunk build up. Thoughts?
Also, there is no mention nor explanation of the steering system in any of the manuals I have. I've done the searches here and it seems I should innitially undo the connection between the rudder and cable to isolate the issue... If I can get it to repeat itself. As far as cable lubrication or checking for something that maybe rubbing the cable or have fallen into it's path that should be cleaned or removed... where do I check, and what needs to be moved or removed to inspect this?
Obviously all help is greatly appreciated.
