I cant find the V-Drive oil location on a 06 sante. I know most of them are under the rear middle seat on the drive, but I dont have an oil check or a location to add oil. I looked at the manual and it shows the location right under the middle back seat (No oil check or add location). I even had my friend who also has a 210 look at it and he was super confused too. He showed me his V - Drive check and its right where mine should be. Anyone have an 06 SANTE that can help me out?
I believe 06 was the first year for the PCM VDrive (left hand rotation prop). It has two square headed access bolts at the 10 and 2 o'clock postions on the VDrive case for checking the lubricant level. The lubricant is a special synthetic Mobiltrans oil and is good for life. It is not a typical routine maintenance item.
I thought 2007 was the first year they switched prop direction. Maybe you have a late model 06? Which way does your prop spin? Also, if it is the serviceable Vdrive, doublecheck the manual. Mine is SAE 30W. Trans is Dexron III.the WakeSlayer
1968 Correct Craft Mustang
I swear that was 07 they switched. Even looking at the manuals I get that impression. Nonetheless, the 07 manual says to fill through the above described 10 and two holes, like H2O stated. I was unable to find where it stated which fluid. WTF...the WakeSlayer
If it is the PCM unit (left hand rotation prop) and it sounds like it is if it backs up to the starboard then remove both fill bolts. The fluid level should be touching the bottom of these threaded holes. Add Mobiltrans SHC 50 synthetic transmission lubricant. PCM part # R190250.
Yep switched in 06 LH prop listen to h20. hes rightOriginally posted by H2O View PostIf it is the PCM unit (left hand rotation prop) and it sounds like it is if it backs up to the starboard then remove both fill bolts. The fluid level should be touching the bottom of these threaded holes. Add Mobiltrans SHC 50 synthetic transmission lubricant. PCM part # R190250.2006 210 SAN! TE
