So I finally got some time to mess with the new (used) boat. After a bit of hesitation I got the nerve to crack open the drains on the manifolds, engine block, and V-drive. Had i not done it and the temp went below freezing, I may have frozen 2 gallons of water inside the engine and never even got to use the boat. Thanks Skinautique for responding to my post on the 2002 SANTE.
So after looking everything over and reading the nautiquemanual and taking my time with things I wanna change out all the fluids just to be sure. Seems like the easiest way is to just get an oil extractor and do it up. Anyone have any opinions on good ones?? I have seen a couple, but one got bad reviews because it was fragile.
Also, anyone know where to get a 2002 Excalibur engine manual?? Or will the 2005 suffice just fine??
Thanks in advance.
Thanks in advance.
