The neutral lock that holds the throttle lever in neutal position has worn to the point it is no longer necessary to disengage it to put the boat in gear. The boat is a 94 Ski Nautique.
There is a little steel lever that acts as a key to hold the throttle in neutal. The lever is worn and no longer extends into the slot on the throttle housing.
Are these little levers available from CC, or is it necessary to replace the entire throttle lever?
Thanks.
Thanks.
