I have an 08 SV211 TE with Jabsco ballast puppies. One is giving me some trouble (just doesn't sound right) so I want to take it off and look at it (could be plugged, maybe the impeller is bad, etc...) I tried to undo the nuts that secure the pump and the entire nut and bolt turns, therefore I can't undo the nut. I can't get at the other side of the bolt because its hidden inside the divider wall between the engine and storage locker. Funny thing is that on my other 2 pumps, the bolts turn as well so they all appear to be doing the same thing. Its almost like they are designed to do this. How do I remove these pumps when the bolt just keeps turning like it is stripped? Am I missing something?
