I need flight clip mounting dimensions?
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    I just got my tower back from the powder coater and I can't find my notes on how far apart to remount my flight clips. Does anyone have a boat hand to measure for me? Thanks.
    Brad
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
  • Shooter
    • Sep 2026
    • 264
    • Orange County California
    • 2003 SANTE 210
    Brad
    What year is the tower...it might make a difference
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      Its on my 2001 Super with an FCT from that year. I am not sure what number it would be called now. Thanks.
      Python Powered
      100 Amp Alternator
      Dual Batteries
        Are your Flight Clips attached to the tower with clamps that go around the bar they attach to, or were that mounted with holes drilled through the bar?
        On boats that had the holes drilled through the bar, we used a template that just sat over the bar, and drilled four 1/4 inch holes through both sides. Then the inner hole was drilled out to 3/4 inch. The clips were then bolted to the bar, and finally, plastic caps were put into the 3/4 holes, and secured with a little RTV "silicone Seal"
        The flight clips were mounted so that one boot of the inner wakeboard put in them was between the two vertical tubes in the tower, and the other boot was in front of the tower.
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          They have the oval clamps. I would just use a wakeboard to guage them but they are at the lake house.
          Python Powered
          100 Amp Alternator
          Dual Batteries
            The bindings on my wake board are about 20 1/2 inches apart, on center.
            Since you have the oval clamp type, I would just wait until you get the boat, wakeboards, and the unmounted clamps together, and mount them for best fit with your wake boards.
            • AirTool
              • 4049
              • Katy, Texas
              darn I went to boat storage tonight and could have measured for you.
              but a agree with daniel...custom fit them. You will be chapped if you mess up the coating relocating the mounts.
