Erractic response when entering code on keypad. Sometimes I have to punch the numbers 4 or 5 times before starting. Any solutions besides replacing keypad?
RE: Keypad not working on 2001 Super Air Nautique
Try changing your code to use a less frequently used number combination. Even if its two pads that still function, a combination of the two will get you going. If all the numeric pads are erratic then replacement is the best option.
Pre 2003 key pads are less likely to last for nine years, assuming its original.
