Looking to put an onboard battery charger
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    Looking for a bit of help.
    I am thinking about putting an onboard battery charger to charge the bank on my 2002 SAN. I have a 24 starting battery and 2 27s for accessory bank. I bring the boat back home in between each visit, so it charges in my garage.
    Also, where would the best place to mount the charger be?
    Thanks in advance
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    I put my onboard charger to the right side of the drivers seat mounted to the floor. When I put the boat in the garage I reach over, grab the cord, and plug it in. Works perfect! I used a Minn Kota charger HERE
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
    • TexanC3
      • Apr 2006
      • 66
      • Katy, Texas
      I use a battery tender that I put under the rear cushion... just plug it in after each use
      http://www.amazon.com/Battery-Tender.../dp/B000CITKCE
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        Those minikota chargers look exactly like what I am looking for. I did look at some of the promariners as well. Since my battery bank is under the portside seat in the back (right in front of the side V-drive compartment), I was thinking about mounting it just inside the V-drive area. I would probably build a facade box to protect it from the ballast sacs when they are full. I know the companies talk about how water resistant these chargers are, but in reality, could they handle a splash or two?
        Eric, Phoenix AZ
        2002 Super Air
          • Jun 2026
          Have you looked at the CTEKs? I'm not sure if their top line one will do a whole bank (I think it will), but a CTEK with a quick connect is what I use. I did not go with the top of the line, so I end up charging 1 battery at a time, but it's very easy to just plug it in using the quick connect (and the CTEK chargers are super small). You can get quick connects that have 3-color flashing LED's (green, yellow, red), which depending on the color give you a rough idea of your charge level just be looking at the flashing LED on the quick connect. Since I don't sit much blasting the stereo (only blast it when I'm pulling), my LED's are almost always green when I am done, but occassionally I'll get a yello on the sound system battery.
          • seanxtreme3000
            • Jun 2010
            • 110
            • North Augusta, SC
            • 2003 Correct Craft Super Air Nautique 210 Team Edition
            sorry not a boff at this stuff. what voltage one do i need and can i use minn kota for 2 batteries, or is that what 2 banks are for LOL. Like i said these elec questions are not a strong point. but thanks to you guys ill get it DONE!
            • ers906
              • Feb 2010
              • 921
              • Phoenix AZ
              Dependng on the # of batteries you have and how quickly you need them charges. In a typical system, you have 12V batteries. Depending on the # you want to be able to charge determines the "banks." One battery per bank, or if they are connected (ie no perko switch) that makes up a bank. I have three batteries, my starter and two accessory batteries which are combined. I am going to use a three bank battery charger set up to ensure that they are maximally charged. Since time is typically not a huge issue, each bank will likely be charged using a 5 amp draw, so the charger will be a 3-bank 15 amp system.
              Eric, Phoenix AZ
              2002 Super Air
              • seanxtreme3000
                • Jun 2010
                • 110
                • North Augusta, SC
                Thanks Man ill need a 2 bank 15 amp
                sean
                • CradGen2
                  • Aug 2020
                  • 1343
                  • Horseheads NY
                  I use the ctek 7000 series I think, top of the line. Also I purchased a bunch of the quick connects. I have (3) 2000 Shuriken (like Kinetic, monster batteries.) and it charges them in about 8 hours. I plug them in friday night when I get to camp and by saturday morning the light is green. It is an awesome charger. I think I paid 130.00 for the ctek online.
                  • wake_fun
                    • 1330
                    • CA
                    • 1995 Super Sport
                    sean
                    That's what I use for my 2 battery setup. I leave it plugged in year round. The chargers know when the batteries get fully charged and then it changes to a low trickle charge automatically so you don't overcharge your batteries.
                    Photo Album
                    Ballast Install 1
                    Ballast Install 2
                    Amp Install
                    PPass Install
                    Alternator Install
                    • wake_fun
                      • 1330
                      • CA
                      • 1995 Super Sport
                      That will work perfect.
                      Photo Album
                      Ballast Install 1
                      Ballast Install 2
                      Amp Install
                      PPass Install
                      Alternator Install
