How on earth? (shaft packing)
    I would think the entire back seat is removable. After all, when the boat was being put together the first time, at the factory, at some point, there was no back seat in the boat.
    I was also under the impression the V-drive boats used a dripless shaft seal that did not use a packing, because it is such a pain to change it.
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      Originally posted by wake_fun View Post
      1.875" = 47.625mm
      <sigh> Clearly re-inforces my point I made at the time. You are correct.
      Nonetheless, do we yet know what size the nuts are on said SAN shaft?
      My 99 definitely does not have dripless.
      the WakeSlayer
      1968 Correct Craft Mustang
      • Red57Bird
        • Aug 2007
        • 381
        • Raleigh, NC/Lake Gaston
        • 2003 Super Air
        Correct, the entire seat is completely removable and is the best way to get the most room possible. The dripless gland was an option on all boats at least up until the 2005 model year, where it may have become a standard in 2006 - I wasn't able to find that out. I have an 03 SAN and I have the traditional packing gland. Not looking forward to the day I have to replace/adjust the packing.
        2003 SAN (current)
        2003 Chaparral 220 SSi (sold)
        • NicksNautique's
          • Jun 2009
          • 16
          • NORTHERN IRELAND
          • 2006 S.A.N. 210 TE 1997 SKI 196
          My 06 210 does not have the dripless packing and they eventually fail anyway!!
          Just much more expensive to replace.
          I.m gonna do my friends seal this weekend so i will post some pics on this thread. Hopefully no one will mind the cut fingers and bruised knuckles from squeezing in around the shaft!
          • ers906
            • Feb 2010
            • 921
            • Phoenix AZ
            Has anyone had the dripless packing fail? Would the first sign be water in the bilge?
            Eric, Phoenix AZ
            G23 550 hp (finally here)
            2002 Super Air
            • Red57Bird
              • Aug 2007
              • 381
              • 2003 Super Air
              #21
              There is a definite lifespan on these, and the biggest issue is that you have to remove the prop shaft to replace.
              2003 SAN (current)
              • ers906
                • Feb 2010
                • 921
                • Phoenix AZ
                #22
                How can you tell if it is failing?
                Eric, Phoenix AZ
                2002 Super Air
                • Red57Bird
                  • Aug 2007
                  • 381
                  • 2003 Super Air
                  #23
                  I checked the web site and while the carbon flange shouldn't ever need to be replaced, they sell a maint. kit that includes a new bellows, o-rings, set screws and clamps. It states that the maint. kit should be used every 6 years. You'll definitely need to disconnect the prop shaft to replace these components.
                  I'm guessing that a sign of failure would be leaking in/around the flange.
                  2003 SAN (current)
                  • ers906
                    • Feb 2010
                    • 921
                    • Phoenix AZ
                    #24
                    Is anyone pre-emptively changing these components out, or are people just doing it as need be? I have a 2002, but not seeing any leaking into the bilge (at least any that I am identifying as anything other than just some splash while surfing.
                    Eric, Phoenix AZ
                    2002 Super Air
                    • WakeSlayer
                      • Sep 2005
                      • 2069
                      • Silver Creek, MN
                      • 1968 Mustang
                      #25
                      There is no reason to unless your packing rope is shot. If it leaks, adjust it so it only let's 4-6 drips per minute. I swear the packing on our 68 was original until I re-did the entire boat two winters ago.
                      the WakeSlayer
                      • MM2007TE
                        • Jul 2026
                        • 1
                        • Wichita Kansas
                        #26
                        Hello - you were discussing replacing the packing on a shaft seal. I have a 2007 236TE (~330 hrs), and have had some excessive water in the bilge. I recently nocticed that my rudder nut was loose because the jam nut had come loose. I tightened that and have not been back out to the lake for assement, but thought the packing would be the next place I look. I noticed a call out of 4-6 drips per minute, is this with the engine running and shaft turning or is it with the shaft stationary? Thanks for any help you can provide.
                        PS - Seems like it is going to be a real task getting into a place where I can see the shaft seal... Thought there?
                        Mark
                        • Jonny Quest
                          • Aug 2014
                          • 457
                          #27
                          I'm OK with 10 to 15 drips per minute with the shaft turning. I prefer a bit more drips per minute for cooling. If the rudder jam nut is tight, that should help reduce water intrusion from the rudder shaft.
