Hello all. My center ballast pump will not turn on. It is on my 09 210 team. I checked the breakers near the perko and under the dash. Any ideas? do not want to have to pull it out and tow to the dealer if I can help it.
When you get a new impeller, get a couple extras. Takes less than 5 minutes to replace them.the WakeSlayer
1968 Correct Craft Mustang
I've replace the impeller in my belly ballast pump. It was very easy to do. I am now going to do the port/starboard pumps before they go out. Just trying to stay ahead of any further issues.
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
I keep about five of the impeller pumps onboard for emergencies (also keep a tsunami pump onboard). for as expensive as they are you would think that their lifespan would be a bit more but such is life. I typically can change out one in about 5 mins, just depends on the location.Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
I have never had to replace an impeller. I installed my pumps spring of 2006. Which means I have the old, supposedly, poor quality ones.the WakeSlayer
can one of you guys do a how to replace ballast pump impellars thread - with pics??????Migs
G21 - En route
SAN 210 TE (Finally)
06 Sky Supreme V220(previous)
05 Sanger V210(previous)
01 MC X1(previous)
99 Air Warrior(previous)
- Feb 2010
- 921
- Phoenix AZ
I am sure I can this weekend. It is very easy if you have the Jabsco ballast puppy pumps. Just remove the three brass screws on the front of the plate, the plate pops off and the impeller is sitting right there. Pop one impeller out, place the other one in, throw some O-ring grease around the O-ring real, and tighten the plate back down. I can add pics on Friday or Sat if you would likeEric, Phoenix AZ
2002 Super Air
that would be awesome!!!! thanks a mill!
My buddy is sending his 230 to Asia where he will not have a dealer or mechanic readily available to work on his boat & I know **** need to swap those impellars soon enough. Id like to be able to teach him(as well as myself) & have him view the "how to" with pics. Makes it easier for us "normal folk" with pics.Migs
G21 - En route
01 MC X1(previous)
